P0101
Mass Air Flow Circuit Range/Performance Problem
P0102
Mass Air Flow Circuit Malfunction (Low Input – Cor “04)
P0103
Mass Air Flow Circuit Malfunction (High Input – Cor “04)
P0105
Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction / 31
P0106
Manifold Absolute Pressure Circuit Problem / 31
P0110
Intake Air Temperature (IAT) Circuit Malfunction / 24
P0112
Intake Air Temperature (IAT) Circuit Low Input – Cor ‘04
P0113
Intake Air Temperature (IAT) Circuit High Input – Cor ‘04
P0115
Engine Coolant Temperature Circuit Malfunction / 22
P0116
Engine Coolant Temperature Circuit Range/Performance Problem (after Engine Operates at Least 20 Minutes, Engine Coolant Temp. Sensor Value is 86°F aka 30°C or less)
P0117
Engine Coolant Temperature Circuit Low Input
P0118
Engine Coolant Temperature Circuit High Input
P0120
Throttle/Pedal Position Sensor/Switch "A" Circuit Malfunction / 41
P0121
Throttle/Pedal Position Sensor/Switch "A" Circuit Range/Performance Problem / 41
P0122
Throttle/Pedal Position Sensor/Switch "A" Circuit Low Input – Cor ‘04
P0123
Throttle/Pedal Position Sensor/Switch "A" Circuit High Input – Cor ‘04
P0125
Insufficient Coolant Temperature for Closed Loop Fuel Control
P0128
Thermostat Malfunction (Coolant Temperature below Thermostat Regulating Temperature)
P0130
O2 Sensor Circuit Malfunction (Bank 1 Sensor 1) / 21
P0133
O2 Sensor Circuit Slow Response (Bank 1 Sensor 1)
P0134
Oxygen Sensor Circuit no activity Detected (Bank 1 Sensor 1) – Cor ‘04
P0135
O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1) /21
P0136
O2 Sensor Circuit Malfunction (Bank 1 Sensor 2) / 27
P0139
O2 Sensor Circuit Slow Response (Bank 1 Sensor 2)
P0141
O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
P0142
O2 Sensor Circuit Malfunction (Bank 1 Sensor 3)
P0147
O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 3)
P0150
O2 Sensor Circuit Malfunction (Bank 2 Sensor 1) / 28
P0153
O2 Sensor Circuit Slow Response (Bank 2 Sensor 1)
P0155
O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1) or Oxygen Sensor Heater Current is Less than 0.25 amp, or Exceeds 2 amps or Voltage Drop for the Heater Exceeds 5 Volts (Cam.)
P0156
O2 Sensor Circuit Malfunction (Bank 2 Sensor 2)
P0159
O2 Sensor Circuit Slow Response (Bank 2 Sensor 2)
P0161
O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2) / 28
P0162
O2 Sensor Circuit Malfunction (Bank 2 Sensor 3)
P0167
O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 3)
P0170
Fuel Trim Malfunction
P0171
System too Lean (Fuel Trim) (tens cars) / 25
P0172
System too Rich (Fuel Trim) / 26
P0174
System too Lean (A/F Lean Malfunction, Bank2) / 25
P0175
System too Rich (Bank2) 26
P0176
Fuel Composition Sensor Circuit Malfunction
P0180
Fuel Temperature Sensor "A" Circuit Malfunction
P0190
Fuel Rail Pressure Sensor Circuit Malfunction / 49
P0191
Fuel Rail Pressure Sensor 15 Circuit Range/Performance (Vist.) / 49
P0201
Cylinder No. 1 Misfires Continuously
P0202
Cylinder No. 2 Misfires Continuously
P0203
Cylinder No. 3 Misfires Continuously
P0204
Cylinder No. 4 Misfires Continuously
P0205
Cylinder No. 5 Misfires Continuously
P0206
Cylinder No. 6 Misfires Continuously
P0300
Random/Multiple Cylinder Misfire Detected or Misfiring Of Multiple Cylinders During Same 200- 1000 Engine Revolutions
P0301
Cylinder 1 Misfire Detected
P0302
Cylinder 2 Misfire Detected
P0303
Cylinder 3 Misfire Detected
P0304
Cylinder 4 Misfire Detected
P0305
Cylinder 5 Misfire Detected
P0306
Cylinder 6 Misfire Detected
P0307
Cylinder 7 Misfire Detected
P0308
Cylinder 8 Misfire Detected
P0309
Cylinder 9 Misfire Detected
P0310
Cylinder 10 Misfire Detected
P0311
Cylinder 11 Misfire Detected
P0312
Cylinder 12 Misfire Detected
P0325
Knock Sensor 1 Circuit Malfunction / 52 (Bank 1 or Single Sensor on Cor ’04)
P0327
Knock Sensor 1 Circuit Low Input (Bank 1 or Single Sensor) - Cor ’04)
P0328
Knock Sensor 1 Circuit High Input (Bank 1 or Single Sensor) - Cor ’04)
P0330
Knock Sensor 2 Circuit Malfunction (Bank 2) / 55
P0335
Crankshaft Position Sensor "A" Circuit Malfunction / 12 or 13 (?)
P0336
Crankshaft Position Sensor "A" Circuit Range/Performance or Deviation in Crankshaft & Camshaft Position Sensor Signals (Cam.)
P0339
Crankshaft Position Sensor "A" Circuit Intermittet – Cor ‘04
P0340
Camshaft Position Sensor Circuit Malfunction (Mar.,Cam. Cor ‘04) / 12
P0341
Camshaft Position Sensor Circuit Range/Performance (Bank 1 or Single Sensor) – Cor ‘04
P0351
Ignition Coil “A” Primary/Secondary Circuit – Cor ‘04
P0352
Ignition Coil “B” Primary/Secondary Circuit – Cor ‘04
P0353
Ignition Coil “C” Primary/Secondary Circuit – Cor ‘04
P0354
Ignition Coil “D” Primary/Secondary Circuit – Cor ‘04
P0385
Crankshaft Position Sensor "B" Circuit Malfunction
P0400
Exhaust Gas Recirculation Flow Malfunction
P0401
Exhaust Gas Recirculation Flow Insufficient Detected With Engine Warm & Driven at 50 MPH for 3-5 Minutes, EGR Gas Sensor Value does Not Exceed Ambient Air Temperature By 72°F aka 40°C (Cam.) / 71
P0402
Exhaust Gas Recirculation Flow Excessive Detected
P0403
Exhaust Gas Recirculation Circuit Malfunction / 71
P0410
Secondary Air Infection System Malfunction
P0411
Secondary Air Injection System Incorrect Flow Detected.
P0412
Secondary Air Infection System Switching Valve "A" Circuit Malfunction
P0420
Catalyst System Efficiency Below Threshold (Bank 1) - With Engine Warm & Driven at 20-50 MPH for 5 Minutes, Heated Oxygen Sensors Have Same Wave Patterns (Cam.)
P0430
Catalyst System Efficiency Below Threshold (Bank 2)
P0440
Evaporative Emission Control System Malfunction
P0441
Evaporative Emission Control System Incorrect Purge Flow
P0442
Evaporative Emission Control System Leak Detected (Small Leak)
P0443
Evaporative Emission Control System Purge Control Valve Circuit Malfunction
P0446
Evaporative Emission Control System Vent Control Malfunction
P0450
Evaporative Emission Control System Pressure Sensor Malfunction
P0451
Evaporative Emission Control System Pressure Sensor Range/Performance
P0452
Evaporative Emission Control System Pressure Sensor Low Input – Cor ‘04
P0453
Evaporative Emission Control System Pressure Sensor High Input – Cor ‘04
P0456
Evaporative Emission Control System Leak Detected (Very Small Leak)
P0500
Vehicle Speed Sensor Malfunction / 42 (Sensor “A” on Cor ’04)
P0505
Idle Control System Malfunction or Idle Speed Varies Greatly from ECM Target Speed
P0510
Closed Throttle Position Switch Malfunction
P0511
Idle Air Control Circuit – Cor ‘04
P0550
Power Steering Pressure Sensor Circuit Malfunction or Closed Throttle Position Switch Does Not Turn On when Vehicle is Driven
P0560
System Voltage – Cor ‘04
P0605
Internal Control Module Read Only Memory (ROM) Error
P0606
ECM/PCM Processor
P0617
Starter Relay Circuit High – Cor ‘04
P0705
Transmission Range Sensor Circuit Malfunction (PRNDL Input) - Cor ‘04
P0710
Transmission Fluid Temperature Sensor Circuit malfunction
P0711
Transmission Fluid Temperature Sensor Circuit Range / Performance
P0715
Input/Turbine Speed Sensor Circuit Malfunction (Mar.)
P0724
Brake Switch “B” Circuit High – Cor ‘04
P0725
Engine Speed Input Circuit Malfunction
P0740
ECT ECU Malfunction
P0741
Totque Converter Clutch Solenoid Performance (Shift Solenoid Valve SL) - Cor ‘04
P0750
Shift Solenoid "A" (SL1) Malfunction or Shift Solenoid A/B Malfunction
P0751
Shift Solenoid “A” perfgormance (Shift Solenoid Valve S1) - Cor ‘04
P0753
Shift Solenoid "A" (SL1) Electrical Malfunction
P0755
Shift Solenoid "B" (SL2) Malfunction or During Normal Driving, Gear Required By ECM Does Not Match Actual Gear (Cam.)
P0756
Shift Solenoid “B” perfgormance (Shift Solenoid Valve S2) - Cor ‘04
P0758
Shift Solenoid "B" (SL2) Electrical Malfunction
P0760
Shift Solenoid "C" Malfunction
P0763
Shift Solenoid "C" Electrical
P0765
Shift Solenoid "D" (S4 or Shift Solenoid Valve No. 4) Malfunction
P0768
Shift Solenoid "D" (S4 or Shift Solenoid Valve No. 4) Electrical
P0770
Shift Solenoid "E" (Lock-Up Solenoid, also called SL solenoid) Malfunction
P0773
Shift Solenoid "E" (Lock-Up Solenoid) Electrical Circuit Malfunction
P0850
Park/Neutral Switch Input Circuit – Cor ‘04
P0973
Shift Solenoid “A” control Citcuit Low (Shift Solenoid Valve S1) - Cor ‘04
P0974
Shift Solenoid “A” control Citcuit High (Shift Solenoid Valve S1) - Cor ‘04
P0976
Shift Solenoid “B” control Citcuit Low (Shift Solenoid Valve S2) - Cor ‘04
P0977
Shift Solenoid “B” control Citcuit High (Shift Solenoid Valve S2) - Cor ‘04
P1100
Atmospheric Press Sensor Malfunction
P1101
Atmospheric Press Sensor Circuit Range / Performance
P1105
Combustion Press Sensor Malfunction
P1120
Accelerator Pedal Position Sensor Circuit Malfunction / 19
P1121
Accelerator Pedal Position Sensor Range/Performance Problem / 19
P1125
Throttle Control Motor Circuit Malfunction / 89
P1126
Magnetic Clutch Circuit Malfunction / 89
P1127
ETCS Actuator Power Source Circuit Malfunction / 89
P1128
Throttle Control Motor Lock Malfunction / 89
P1129
Electric Throttle Control System Malfunction / 89
P1130
A/F Sensor Circuit Range/Performance Malfunction (Bank 1 Sensor 1)
P1133
A/F Sensor Circuit Response Malfunction (Bank 1 Sensor 1)
P1135
A/F Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
P1136
A/F Sensor Circuit Malfunction (Bank 1 Sensor 2)
P1139
A/F Sensor Circuit Slow Response (Bank 1 Sensor 2)
P1141
A/F Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
P1150
A/F Sensor Circuit Range/Performance Malfunction (Bank 2 Sensor 1)
P1153
A/F Sensor Circuit Response Malfunction (Bank 2 Sensor 1)
P1155
A/F Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
P1156
A/F Sensor Circuit Malfunction (Bank 2 Sensor 2)
P1159
A/F Sensor Circuit Slow Response (Bank 2 Sensor 2)
P1161
A/F Sensor Heater Circuit Malfunction (Bank 2 Sensor 2)
P1180
CNG Pressure Sensor Circuit Malfunction
P1185
CNG Temperature Sensor Circuit Malfunction
P1190
Fuel Pressure Regulator Malfunction
P1200
Fuel Pump Relay/ECU Circuit Malfunction
P1205
Electric Air Pump Circuit Malfunction.
P1210
Injector Control Pressure Above Expected Level / 92
P1215
EDU Circuit Malfunction (Ath.) / 97
P1220
Timer Control Circuit Malfunction
P1221
Venturi Control Circuit Malfunction
P1225
Spill Control Circuit Malfunction
P1230
Venturi Position Sensor Malfunction
P1235
High Pressure Fuel Pump Circuit Malfunction or “Fuel Pump Control Out Of Range” / 78
P1240
Fuel Shutoff Valve Circuit for Delivery Pipe Malfunction
P1245
Fuel Shutoff Valve Circuit for Pressure Regulator Malfunction
P1300
Igniter Circuit Malfunction / 14
P1305
Igniter No. 2 Circuit Malfunction / 15
P1310
Igniter No. 3 Circuit Malfunction /15
P1315
Igniter No. 4 Circuit Malfunction
P1320
Igniter No. 5 Circuit Malfunction
P1325
Igniter No. 6 Circuit Malfunction
P1330
Igniter No. 7 Circuit Malfunction
P1335
Crankshaft Position Sensor (CKP) Circuit Malfunction (During engine running) (Vist., Cam.) / 13
P1340
Igniter No. 8 Circuit Malfunction (1998-2000 Land Cruiser & 2000 Tundra)
P1345
VVT (Variable Valve Timing) Sensor/Camshaft Position Sensor Circ. Malfunction (Bank1)
P1346
VVT (Variable Valve Timing) Sensor/Camshaft Position Sensor Circuit Range/Performance Problem (Bank 1) / 18
P1349
VVT (Variable Valve Timing) System Malfunction (Bank 1) 22 / 59
P1350
VVT (Variable Valve Timing) Sensor/Camshaft Position Sensor Circ. Malfunction (Bank2)
P1351
VVT (Variable Valve Timing) Sensor/Camshaft Position Sensor Circuit Range/Performance Problem (Bank 2)
P1354
VVT (Variable Valve Timing) System Malfunction (Bank 2)
P1357
Exhaust VVT Sensor/Camshaft Position Sensor Circuit Malfunction (Bank 1)
P1358
Exhaust VVT Sensor/Camshaft Position Sensor Circuit Malfunction (Bank 2)
P1360
P1365
P1400
Sub Throttle Position Sensor Circuit Malfunction
P1401
Sub Throttle Position Sensor Circuit Range/Performance Problem
P1405
Turbo Pressure Sensor Circuit Malfunction
P1406
Turbo Pressure Sensor Circuit Range/Performance Problem
P1410
EGR Valve Position Sensor Circuit Malfunction
P1411
EGR Valve Position Sensor Circuit Range/Performance Problem
P1415
Air Pump Circuit Malfunction/ (AIR) System Bank 1 / 58
P1416
Port Air Circuit Malfunction/ (AIR) System Bank 2 / 58
P1420
Intake Constrictor CTRL Circuit Open or Short
P1430
Vacuum Sensor for HC Adsorber and Catalyst (HCAC) System Circuit Malfunction (HV)
P1431
Vacuum Sensor for HC Adsorber and Catalyst (HCAC) System Circuit Range/Performance Problem
P1436
Toyota-HCAC-System By-Pass Value Impromevent-Open Malfunction (Pri)
P1437
Toyota-HCAC-System By-Pass Valve Close Malfunction
P1437
Vacuum Line Malfunction (HV)
P1455
Vapor Reducing Fuel Tank System Malfunction
P1455
Vapor Reducing Fuel Tank System Leak Detected (Small Leak) (HV)
P1500
Starter Signal Circuit Malfunction
P1505
Switch Signal Malfunction
P1510
Boost Pressure Control Malfunction
P1511
Boost Pressure Low Malfunction
P1512
Boost Pressure High Malfunction
P1515
Inter Cooler System Malfunction
P1520
Stop Light Switch Circuit Malfunction (A/T)
P1525
Resolver Circuit Malfunction
P1565
Cruise Control Main Switch Circuit Malfunction
P1566
Input Signal Circuit Abnormal or Cruise Control Main Switch Circuit Fault
P1600
ECM BATT Malfunction
P1605
Knock Control CPU Malfunction
P1610
Combustion Control CPU Malfunction
P1620
ECT1 Signal Circuit Malfunction
P1625
ESA1 Signal Circuit Malfunction
P1626
ESA2 Signal Circuit Malfunction
P1627
ESA3 Signal Circuit Malfunction
P1630
Traction Control System Malfunction
P1633
ECM Malfunction (ETCS Circuit) or Electronic Throttle Control System (ETCS) Circuit ECM Malfunction
P1636
HV ECU Malfunction
P1637
E(G?)STP signal Malfunction (ESTP Signal Malfunction – Pri)
P1645
Body ECU Malfunction
P1650
Fuel Pressure Up VSV Circuit Malfunction
P1651
VSV For ACIS Circuit Malfunction
P1652
IACV Control Circuit Malfunction
P1653
SCV Circuit Malfunction / 58
P1654
Idle Up VSV Circuit Malfunction
P1655
Idle Purge VSV Circuit Malfunction
P1656
OCV (Oil Control Valve) Circuit Malfunction (Bank 1) / 39
P1657
Purge Cut VSV Circuit Malfunction
P1658
Waste Gate Valve Control Circuit Malfunction
P1659
Super Charger Control Circuit Malfunction
P1660
Air Bleed Control Circuit Malfunction
P1661
Exhaust Gas Control Valve Control Circuit Malfunction
P1662
Exhaust Bypass Valve Control Circuit Malfunction
P1663
OCV (Oil Control Valve) Circuit Malfunction (Bank 2)
P1666
Intake Air Control VSV No.2 Circuit Malfunction
P1667
TCV Circuit Malfunction
P1668
VSV for AICV Circuit Malfunction
P1690
OCV For VVTL Circuit Malfunction (Bank 1)
P1692
OCV For VVTL Open Malfunction (Bank 1)
P1693
OCV For VVTL Close Malfunction (Bank 1)
P1695
OCV For VVTL Circuit Malfunction (Bank 2)
P1697
OCV For VVTL Open Malfunction (Bank 2)
P1698
OCV For VVTL Close Malfunction (Bank 2)
P1700
Speed Sensor No.2 Malfunction
P1705
NC2 (Direct Clutch Speed Sensor) Revolution Sensor Circuit malfunction or Direct Clutch Speed Sensor Output is 300 RPM or less with Vehicle at 20 MPH or more & with Park/Neutral Position Switch Off
P1710
Steering Sensor Circuit Malfunction
P1715
Rear Wheel Sensor Circuit Malfunction
P1720
DC Clutch Forced Release Circuit Malfunction
P1725
NT Revolution Sensor or Input Turbine Speed Sensor Circuit Malfunction
P1730
NC Revolution Sensor Circuit Malfunction or Counter Gear Speed Sensor Circuit Fault
P1735
Right Front Speed Sensor Circuit Malfunction
P1740
Left Front Speed Sensor Circuit Malfunction
P1745
Transmission Fluid Temperature Sensor No.2 Circuit Malfunction
P1753
Shift Solenoid No.4 Circuit Malfunction
P1755
Linear Solenoid for Lock Up Ctrl Circ. Malfunction
P1760
Linear Solenoid for Line Pressure Control Circuit Malfunction or Shift Solenoid Valve SLT Fault or Linear Solenoid for Lock-Up Control Circuit Malfunction
P1765
Linear Solenoid 24 for Accumulator Pressure Control Circuit Malfunction (Shift Solenoid Valve “SLN” malfunction) or with Engine Warm, Current Flow to Shift Solenoid Valve “SLN” is 0.2 Amp or less for One Second with Engine at 500 RPM or more, or with Park/Neutral Position Switch Off
P1770
Deferential Lock Solenoid No.1 Circuit Malfunction
P1775
Deferential Lock Solenoid No.2 Circuit Malfunction
P1780
Park/Neutral Position (PNP) Switch malfunction (A/T only)
P1782
Transfer L4 SW Circuit Malfunction
P1783
Transfer N SW Circuit Malfunction
P1785
Auto Clutch System Malfunction
P1790
ST Solenoid (Shift solenoid valve ST) Circuit Malfunction
P1793
Shift Solenoid ST Circuit Malfunction
P1800
Automatic Transmission Operation Circuit Malfunction
P1805
Communication (between EFI ECU and Transmission ECU) Circuit Malfunction
P1810
Communication for Torque Control Circuit Malfunction
P1820
NIN Sensor Circuit Malfunction
P1825
NOUT Sensor Circuit Malfunction
P1845
PTO Sensor Circuit Malfunction
P1885
SLS Circuit Malfunction
P1888
P1890
SLC Circuit Malfunction
P1891
P1895
DSU Circuit Malfunction
P2195
Oxygen Sensor Signal Stuck Lean (Bank 1 Sensor 1) – Cor ‘04
P2196
Oxygen Sensor Signal Stuck Rich (Bank 1 Sensor 1) – Cor ‘04
P2716
Pressure Control Solenoid “D” Electrical (Shift Solenoid Valve SLT) - Cor ‘04
P2769
Torque Converter Clutch Solenoid Circuit Low (Shift Solenoid Valve SL) – Cor ‘04
P2770
Torque Converter Clutch Solenoid Circuit High (Shift Solenoid Valve SL) - Cor ‘04
P3000
HV Battery Malfunction
P3001
26 Battery ECU malfunction
P3002
HV ECU communication malfunction
P3004
Power Cable Malfunction
P3005
High voltage fuse snapped [sic] 27
P3006
Battery SOC are uneven 28
P3009
Leak detected 29 (Electric leak from high–voltage
P3010
Battery total resistance malfunction
P3011
to P3029 Battery block malfunction 30
P3030
Battery voltage detective line snapped [sic]
P3060
Battery temperature sensor circuit malfunction
P3076
Abnormal air flow by battery cooling fan
P3077
Battery cooling fan motor circuit malfunction
P3100
HV ECU Malfunction
P3101
Engine System Malfunction
P3105
Battery ECU Communication Circuit Malfunction
P3106
ECM Communication Circuit Malfunction
P3107
Airbag ECU Communication Circuit Malfunction
P3108
A/C Amplifier Communication Circuit Malfunction
P3109
32 Brake ECU Communication Circuit Malfunction
P3110
IGCT relay is always closed
P3115
33 HV battery current sensor malfunction
P3115
System Main Relay Malfunction
P3120
HV Transaxle Malfunction
P3125
34 Converter & Inverter Assembly Malfunction
P3130
Inverter Cooling System Malfunction
P3135
Circuit Breaker Sensor Malfunction
P3140
Interlock Malfunction
P3145
Vehicle Speed Sensor Circuit Malfunction
Коды ошибок и неисправностей автобуса TOYOTA
17.01.2013 12:59:32
